081 Heads
Old Jan 3, 2007 | 02:57 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
081 Heads
Hey Everyone.
Today i pulled the vavle covers off my 146000 miles LB9, and to my surprise, what i was bless with was an absolutaly mint inside. Heads look as if their brand new.
Now, what kind of flow could i get out of these heads with a little porting on a 350?
I would add some better vavles and valve springs.
also would like to know how much lift these heads could take.
What their combustion chamber size is, etc.
Thanks!
Old Jan 3, 2007 | 03:03 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
if you'll be using the 081's on a 350 you want to go up to a 1.94x 1.60" valve set. With this and a full home port job you'll easily get over 230cfm intake and 170+ex. will support 400++hp. Search mine and Sitting Bull's posts on porting 305 heads. its all there. Don't worry about how much lift the stock heads will take. if you want to know measure it yourself. have a machine shop machine the guide bosses for teflon seals. Shorten the boss by .200".
Drill and pin the rocker studs yourself.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
