valve seals/gaskets
Old Jan 4, 2007 | 07:01 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
valve seals/gaskets
I bought a gasket kit. I'm slowly but surely replacing gaskets. Just to keep my car up to date and maintained since the previous owners did not.
I still have to do the intake manifold gaskets. Anything i need to know or should be aware of or any do's and don'ts????
Should i use gasket sealer or is there a risk it will leak into a spot i dont want it to? Can i just rely on placing the gaskets in?
I know the sealer dries quickly n hardens but i don't want to use too much and have it leak over into an area i do not want to clog.
Just any tips or suggestions please.
Old Jan 4, 2007 | 08:21 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
I'm assuming you're working on the V8 although the V6 is similar.
Read up on how to remove and reinstall the distributor and set it back in time.
Too many people have problems after they pull the distributor, spin the motor, and realize they have no clue how to put it back in time.
Modern gaskets are high tech. The reason they say don't add sealant is because they have already incorporated this into the gasket and adding it will only add to clogging of the oil pump pickup and radiator.
You do have to put a dab of silicone at the 4 corners where the intake meets the block. It's in all the instructions.
What they don't emphasize enough is surface prep. The mating surfaces have to be cleaned down to bright shiny metal. Most folks think this means scraping the big stuff off with a paint scraper. Us pros use a "scotch-brite" pad on a die grinder.
It's ok to add a small amount of gasket sealer to almost any gasket. EXCEPT steel shim head gaskets. A long technical explanation will show how the extra sealant will cause a problem where one wouldn't exist.
One more tip: If people in Alabama have sucessfully done it, it can't be that hard.
Old Jan 4, 2007 | 08:42 PM
Bobby_80s's Avatar
Axle/Gears: no idea
yes v8 correct sorry about that. v8 305 5.0 tpi fuel injected 1986 trans am
Thanks for the tips.
What instructions are you referring to. My kit didnt really come with anything in big detail.
I have a chiltons manual but not sure if that will help all the way but mayeb between your advice and the manual i should be in good shape.
thanks
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
HikoriYami
Sep 21, 2015 07:11 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
