Please help with shims on valve spring install
Old Jan 13, 2007 | 01:44 PM
Max's Avatar
Max
Car: '89 Camaro Convertible
Engine: LB9 Heads/LT1 Cam Holley 670 Carb
Transmission: T5 Manual
I have measured my valve stems with an installed height micrometer and the total height on the intake is 1.820 and 1.900 on the exhaust.
My springs are rated at 130 lbs. at 1.800" so this is the approximate installed height I'm shooting for.
On the intake I used one .030" shim and came up with an installed height of 1.7825". Not Bad right.
On the exhaust I stacked a .060", a .030" and a .015" and ended up with an installed height of 1.8025". Again, not bad.
My concern now is that when I use these shims there is not much left of the spring pocket depth. The heads are Chevy 081 (LB9) castings. There is just a very small amount of casting material that rises high enough to help locate the springs. Should I be concerned about the bottoms of the springs shifting back and forth?
Old Jan 13, 2007 | 03:39 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
You'll be ok. its the inner diameter of the valve guide boss that locates the spring, not the outer diameter of the spring pocket. just recheck you installed heights and you're good to go.
Old Jan 14, 2007 | 07:39 AM
Vader's Avatar
If you've done some guide machining and/or are using single springs, you always have the option of spring cups.
Old Jan 14, 2007 | 08:51 AM
Max's Avatar
Max
There has not been any machining of the guides. I'm using a single spring with a damper. I am not familiar with spring cups. would they install under or over the springs?
BTW, thanks for your replies.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
gta90
Sep 15, 2015 04:00 PM
sailtexas186548
Aug 26, 2015 03:32 PM
TheExaminer
Aug 25, 2015 07:34 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
