FUEL TANK
Old Jan 18, 2007 | 08:55 AM
CALI CAMARO's Avatar
FUEL TANK
my fuel tank was leaking where the filler neck meets the tank.i dropped the tank and the filler neck fits kind of loose,is it suppossed to be like that?any suggestions on a quick fix will be appreciated
Old Jan 18, 2007 | 01:03 PM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
If it is a 91 camaro it can be fixed at the dealership free of charge. If its loose, just go and get another one from a junkyard. DO NOT WELD IT. Unless you have a death wish. Then spark away.
Old Jan 18, 2007 | 07:28 PM
my bad its a 89rs.is this something common?I just had my fuel pump replaced and when i got it back the fuel tank was leaking,but i dont think they changed anything
Old Jan 18, 2007 | 07:47 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
They probably forgot to tighten one of the hoses or they cracked the filler neck..
Old Jan 18, 2007 | 09:54 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
If someone else did the fuel pump...and it wasnt leaking before....Id certainly be letting them know that the filler neck wasnt loose when you brought it in, and it is now....
Old Jan 19, 2007 | 08:54 AM
THANK'S for the replies.I've had words with my mechanic already and it think its safe to say i'am not going back!I was too busy and couldn't do it my self at the time.next time I'll make time!now I have to go and hunt 1 down at the junk yard.
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Apr 14, 2017 05:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Glowsock
Aug 26, 2015 12:28 AM
AkDrifted
Aug 17, 2015 07:45 PM
