Cam Swapping
Old Jan 18, 2007 | 12:15 PM
USCBoi's Avatar
Car: 1991 Chevrolet Camaro RS
Engine: 305 TBI
Transmission: TH700-R4
Cam Swapping
If a different TYPE of camshaft, i.e. a flat tappet is swapped into a roller rocker block, is it even remotely possible that the cam gear is smaller than the stock gear? Which would slowly but surely lead to a change in timing settings, over slow intervals of time? I'm chasing a hunch...any info would be appreciated.
Old Jan 18, 2007 | 12:35 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Yes, it's a different timing set altogether IIRC.
I don't think that would slowly change your ignition timing settings though. A loose distributor bolt would do that.
Old Jan 18, 2007 | 12:47 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Factory roller cams use a different timing set than the flat-tappet and retro-roller cams, but the sizes should be about the same.
Regardless, there's no way it could cause timing to slowly "drift".
Old Jan 18, 2007 | 04:49 PM
USCBoi's Avatar
Engine: 305 TBI
Thanks. I keep checking the dist. bolt. and it's tighter than ever. But my timing slowly goes to 18 advanced, and then it fouls my plugs. any thoughts?
Old Jan 18, 2007 | 05:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's unusual that it advances. Usually if there was a mechanical problem it would retard the timing.
Old Jan 18, 2007 | 10:56 PM
Sonix's Avatar
Car: 1982 Trans-Am
how slowly is slowly? days? minutes? months?
Balancer ring slipping, but again, I think that would show up as retard.
It advances to 18*? Not 19, not 20, not 16, but 18? Don't you think that's kind of strange?
anesthes
Mar 10, 2016 10:35 PM
beastin91rs
Oct 9, 2015 07:38 AM
Cameeeero
Sep 18, 2015 04:00 PM
theshackle
Aug 22, 2015 06:52 PM
theurge
Aug 21, 2015 12:46 PM
