PLEASE HELP,NEED SLEEP, 305TPI RUNS ROUGH,MISFIRES ON PASS. SIDE ALSO PLUG R WET
Old Jan 20, 2007 | 10:21 PM
tripingeorge3's Avatar
I solved my service engine light problem, but it runs rough and has a misfire on passenger side. i pulled my new plugs out and they were blackend and wet, but didn't smell like gas or oil. its sounds like its around plug 6 and 8. So i then unplugged them one at a time and got a slight difference but it was extremely hard to tell. i cleaned the plugs only to have them do the same thing.
THINGS I HAVE NEW:
Old Jan 20, 2007 | 11:45 PM
MARO-MAN's Avatar
Car: I've had 4 thrid gens!!
Engine: Someday again I will have another!!
Did this just happen after you replaced the wires/plugs?
Wires are in the right order?
Getting spark to the cylinders in question?
Did you replace cap and rotor?
-Nick.
Firing order diagram:
https://www.thirdgen.org/forums/atta...-chevyfire.gif
Old Jan 21, 2007 | 10:55 AM
yes, i replaced cap, rotor, and ignition module.
Old Jan 21, 2007 | 11:07 AM
mark wells's Avatar
Car: 85 Trans Am
Engine: 383 ci
Axle/Gears: posi 342
Sounds like engine is cold the black stuff is probably carbon, and the plug also being wet is probably condensation. Did this problem just happen after the tune up or were you trying to fix it with a tune up? If there is a lot of carbon comming loose then there is also a chance that some of it got stuck in a valve. I would do a compression test/ leak down test to see if cylinder is holding compression.
Old Jan 21, 2007 | 05:34 PM
MARO-MAN's Avatar
You need to supply us with more info. Like did this problem happen before or after the tune up?
Old Jan 21, 2007 | 06:52 PM
kjvail1204's Avatar
Ok from my experiance either your not getting spark there at all or your in the wrong order, give it a little gas if it back fires, or falmes come out the carb, tbi then you have them in the wrong order, other wise test the spark to each plug, you can use a screw driver, and make sure you are getting a good BLUE spark.
customblackbird
Aug 15, 2021 10:16 PM
db057
Aug 22, 2015 08:17 PM
Bradsaundry
Aug 12, 2015 12:34 AM
marcusaw
Aug 10, 2015 08:13 AM
Sherpajames
Aug 7, 2015 06:56 PM
