clunk
Old Jan 23, 2007 | 04:38 PM
91 camaro rs's Avatar
Car: 91 rs
Engine: 305tbi
Axle/Gears: 3.27 9bolt
clunk
when i push the gas hard my camaro makes a clunk sound. my dad thinks its either a motor or tranny mount or the brakes, what do you think it could be?
Old Jan 23, 2007 | 05:20 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
could be your track brace [ panard ] bar , came loose from the body . [ mine did ] goes from upper rt. of rear axle to lt. side of body . mine was clunking when i went over r/r tracks and speed bumps . pull lt. rear wheel and look , on mine all 3 bolts had fallen out . hope this helps . uncle tom , ret. acft. mech.
Old Jan 23, 2007 | 05:39 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
When it does this, lay your hand on the tranny tunnel. If it is the transmission mount you will feel it clunk.
Old Jan 23, 2007 | 06:35 PM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
Sounds like the rear end. Had two cars that did this.
Old Jan 23, 2007 | 08:28 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
Second vote for trany mount, that is what mine did.
Old Jan 31, 2007 | 02:27 PM
Car: 91 rs
Engine: 305tbi
update
forgot to add that it only happens from a dead stop! can feel it in the whole car. need help quick
Old Jan 31, 2007 | 03:52 PM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
Rear end problem. Proably the u bolts are loose. When you take off the rear end rocks back. Leave it and it will be expensive when you have to change out driveshaft.
Old Feb 2, 2007 | 02:31 PM
Car: 91 rs
Engine: 305tbi
what do i need
anything other than a socket set to fix this, is it an easy fix?
F-body driver
Mar 6, 2023 11:44 AM
luvofjah
Sep 26, 2015 08:28 PM
ynk1121
Sep 12, 2015 12:27 AM
Ragtop Man
Sep 12, 2015 12:23 AM
BlackBoulder
Aug 11, 2015 11:15 PM
