need help immediatly!!
Old Jan 25, 2007 | 06:54 AM
IceBlue91z28's Avatar
Car: 1991 Camaro Z28
Transmission: Built 700r4
Ok heres the general info...1989 z28 with a 5 speed and a 350 carbed.
heres the problem: car wont turn over
it happened a few days ago. I would turn the key and nothing would happen. Then I would move the shifter around while the key was in the start position and that worked for about a day. Then it stopped again. I tried splicing the clutch safety switch together to see if that wasnt allowing it to turn over but that didnt work. Then I checked the starter. The ground seemed a little loose so i tightened it the best I could, and i went in the car turned the key twice and the third time it started. Ok cool but then I drove it from my parents house to my house on the highway and I go to try to go to work this morning and nothing again. The ground is tight, the started didnt seem to be faiing...what else should I check/do to get this thing to work. Please help
thanks
Old Jan 25, 2007 | 11:28 AM
Vader's Avatar
Does your '89 still have VATS enabled?
Old Jan 25, 2007 | 11:44 AM
no vats
Old Jan 25, 2007 | 11:49 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Have you checked the battery and cables? The battery might be running low on juice to crank the motor over try jumping it to see if it starts right up.
Old Jan 25, 2007 | 02:08 PM
the battery is fine it started yeasterday with out a need for a charge and then just randomly stoped starting again
Old Jan 25, 2007 | 03:08 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
sounds like a bad starter... although you could make sure by checking for a +12VDC signal at the small wire connection on the starter... with +12VDC there, the engine should crank (assuming a good ground and good positive connection to the battery)... If it doesn't, then either the battery is fried (the starter is pulling the battery down way past 10 volts), or the starter is bad... If the battery voltage doesn't change when you apply +12V to the little wire connection, then you more than likely have a bad starter...
Old Jan 25, 2007 | 06:15 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
ya i agree with thirdgen88 just start testing all the connections and grounds..... but it does sound like a bad starter....i love how they go all intermittent onya..sometimes they work sometimes they dont...dang starters
Old Jan 25, 2007 | 07:59 PM
could it just be a bad solenoid instead of the whole starter?
dimented24x7
May 31, 2004 09:01 PM
firebirdvert305
Theoretical and Street Racing
44
May 5, 2004 07:08 PM
CamarosRUS
May 5, 2004 10:14 AM
purdyred89
May 1, 2004 06:35 AM
Angel
Apr 14, 2004 11:10 PM
