Can somebody help me out with this...
Old Jan 26, 2007 | 06:24 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
Transmission: Tremec T-56
This seems like a dumb question but i sold my motor last year (305 tpi) for a 383 carb and i cant seem to remember what goes on the radiator below the radiator cap. I know there is the overflow hose (small one) and a 5/8" right below that, i have no idea where that goes.
Old Jan 26, 2007 | 08:17 PM
Gramps's Avatar
Car: 87 Camaro IROC
itll go to either your oil cooler or your heater core...if you dont have a oil cooler then itll go straight to your firewall and come out and go into the TB and into the intake manifold and then thru the block.
Old Jan 27, 2007 | 10:28 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i thought the next hole was for the trans cooler, and there should be a hole lower as well
Old Jan 28, 2007 | 12:01 AM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
ok, heres what im talking about. I have the other hoses ran from the water pump to the firewall and from the firewall to the intake by the thermostat. where does this go?
Old Jan 29, 2007 | 09:24 AM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
anyone have a pic that shows where that hose goes?
Old Jan 29, 2007 | 09:38 AM
You use either the hose that goes from the water pump to the heater core, or the one that goes from the radiator to the heater core. Not both. Pick one, hook the hose to it; plug the other.
Are you still using the factory oil cooler?
Old Jan 29, 2007 | 11:27 AM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
So the way i have it will work fine if i plug the one on the radiator? The oil cooler is build in the radiator isnt it? Im putting a t-56 in at the same time so i dont need the use of the oil cooler.
Old Jan 29, 2007 | 11:54 AM
No. It is a sort of "sandwich adapter" between the oil filter and the place on the engine block that the filter normally goes. Coolant circulates through it and cools the motor oil. There are normally some metal lines that connect to the heater system and then pass under the front of the motor and around to the oil filter.
There's no connection between the engine oil cooler and what transmission you're using. Nothing to do with each other.
Old Jan 29, 2007 | 12:50 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
I dont think i have an oil cooler??? I thought you were refering to the transmission lines that run into the radiator.
Old Jan 29, 2007 | 01:14 PM
Maybe not... but the car DID, when it was new. They're not the most effective things in the world, and the steel tubing that carries coolant to it often rusts through, and people take it off and throw it away.
So if you don't have it, don't worry about it.
IMO it's easier to hook the heater hose to the fitting on the radiator, and put a brass pipe plug in the water pump. Also less chance of it blowing off or leaking or otherwise failing, as compared to an extra piece of rubber on the radiator.
Old Jan 29, 2007 | 02:50 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
yeah i was worried about the plug on the radiator blowing off, i think ill just rework the hoses to what you suggested. Thanks for the help, can't wait to get this thing running
Old Jan 29, 2007 | 04:33 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Either just plug the hole in the radiator, (only 15psi there) or take the hose from the top of the water pump and hook it to the radiator, plug the hole in the top of the water pump. It's the return line from the heater core.
92firebirdguy
Sep 1, 2016 07:53 AM
luvofjah
Sep 26, 2015 08:28 PM
Blue419
Sep 10, 2015 01:03 PM
Thaney9
Aug 7, 2015 08:25 PM
CD MaroMan 91
Mar 13, 2002 04:15 PM
