Help Engine wont start
Old Jan 28, 2007 | 03:47 PM
tri power's Avatar
I bought a 1992 Camaro 3.1 engine the car has been sitting for a while replaced fuel pump engine will not start plugs are firing and is getting gas HELP!!!!!!!!!!!!!
Old Jan 28, 2007 | 05:05 PM
86z28305's Avatar
Car: 1986 Chevrolet Camaro Z28/99 Aurora
Engine: LB9 5.0 TPI/4.0 V8
Transmission: 700r4/?
Axle/Gears: 2.73/3.08
So you have spark and fuel. How about compression?
Old Jan 28, 2007 | 05:23 PM
tri power's Avatar
Car will run on starting fluid.
Old Jan 28, 2007 | 05:31 PM
86z28305's Avatar
Is it getting enough air?
Old Jan 28, 2007 | 06:03 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
By "car is getting gas" please elaborate... What is your fuel pressure at the schrader valve? If the car starts on starting fluid than its probably not getting gas!
I'd rule out VATS, but you haven't said anything about the security light (VATS disables the injectors and the starter enable relay).
Without knowing fuel pressure its hard to say, but if your not going to check it, then you should investigate the fuel pump relay. Also note if you hear the fuel pump prime from the back when the key is turned but not started. TO make it prime again you have to wait 10 or 15 seconds with the key out.
Bad gas? Old gas? Do you have gas in it?
If it sat for forever you might have seized a piston in the cylinder - and broke it when you started the car, doubtful, but if you check fuel pressure and its good, then the next logical step is compression - as you've checked for spark already.
Old Jan 28, 2007 | 06:05 PM
tri power's Avatar
Yes it is getting enough air.
It has fresh gas all the relays under the hood checked good I do not know about the fuel pressure I know the valve where you check the fuel pressure is pushing out gas where you push it in.
Old Jan 28, 2007 | 09:02 PM
jocool's Avatar
Car: 89 Iroc & 88 Firecird & 86 Camaro
Engine: 350 TPI & 305 TBI & 305 Carb
As stated above, you need to check the fuel pressure with a gauge. Thats where I would start.
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
