rod/ROD BOLT, failed OR DID IT??
Old Jan 28, 2007 | 10:30 PM
grumpyvette's Avatar
I see rods and rod bolt failures blamed frequently when engines self destruct at high rpms, but its NOT always what it at first might appear to be....are there any detailed pictures of the rods or rod bolts that failed??? in many cases the source of the problem can be seen with a careful detailed exam, if you don,t know the SOURCE of the problem your doomed to repeat the sequence... and keep in mind a good deal of what might appear to be rod/rodbolt failures, are ACTUALLY the result of over reving the valve train,and loss of valve train control, OR detonation, theres no way to compress a bent valve or broken piston ring land without potentially damaging the rods
http://www.arp-bolts.com/Tech/T4_Why...4_01_Why0.html
http://www.arp-bolts.com/Tech/T4_Why...4_01_Why1.html
http://www.arp-bolts.com/Tech/T4_Why...4_01_Why2.html
http://www.arp-bolts.com/Tech/T4_Why...4_01_Why3.html
http://www.arp-bolts.com/Tech/T4_Why...4_01_Why4.html
http://www.arp-bolts.com/Tech/T4_Why...4_01_Why5.html
http://www.arp-bolts.com/Tech/T4_Why...4_01_Why6.html
Old Jan 28, 2007 | 11:38 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Rod bolts don't usually fail like you normally think. The rod bolt holds the end cap onto the rod. On the compression stroke, the piston and con rod are forced down onto the crank by the explosion on top of the piston which puts no stress at all on the rod bolts. The crank isn't pulling the piston and rod down so there's little stress on the rod bolts.
Now the piston and rod are at the bottom of the cylinder and the crank is pushing them back up again putting little stress on the rod bolts. At the top of the cylinder, all that weight of the piston and rod is moving upward very quickly and comes to a sudden stop at the top just before they hit the head. That's where the rod bolts see the most abuse. They're never in a position to break or snap but at the top of the cylinder, they can be stretched. A rod bolt failure will show a stretched bolt. If the bolt is sheared off, something else happened first to cause the failure.
Now with typical factory style rod bolt with nut design, a failure can be because the bolt got stretched slightly which caused the torque on the nut to loosen then back itself right off, cap falls off, big damage etc.
A piston hitting a valve will destroy the piston and rod before the rod bolts get damaged since there's no excess forces being put on the rod bolts in that damage situation. The crank is pushing up on the rod, the end cap and bolts are on the bottom simply being pulled up by the rod. When the piston contacts a valve, the piston and rod stop while the crank is still pushing them up. The crank tries to push the rod up. Since the rod can't go through the crank, it can't hurt the rod bolts.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Glowsock
Sep 6, 2015 06:40 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
