Camshaft install
Old Jan 29, 2007 | 08:54 PM
redlsone's Avatar
Camshaft install
I want to install a new camshaft. How hard is it once youve already installed the engine. It had really low specs and i dont have money for both heads and came so i thought i would do the cam first. Im also doing 1.6 rockers from my 1.5"s. Do you think a 3000 stall would be too much or do you need more info?
I have afr 195 heads with flat top pistons,and and edlebrock750 card with an air gap intake,headman headers and still neeed to do my posi. any info would be great.
Old Jan 29, 2007 | 09:04 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
its not really hard to install a cam inside a car.. it will just take time.. take off the whole front assembly(alternator, power steering, water pump, AC, etc), intake manifold, radiator, and possibly the front clip(just to make it easier).. then rockers come off, pushrods out, lifters out, oilpan dropped, timing cover off, then turn the motor to TDC, cam gear off, cam pulled out, new cam lubed and put in, cam gear and chain on, timing cover, oilpan, lifters, pushrods, rockers, intake manifold, etc..
the hardest part will be getting a seal back onto the oilpan.. once its broken, its hard to seal back up.. silicone will be your best friend here..
Old Jan 29, 2007 | 09:15 PM
redlsone's Avatar
I already have an oil leak from the install so I guess I would make a day of it. Next question I would ask is what specs? I already get crappy mileage so its up in the air. I wuld be mostly high way mileage but hit the track a few times a years. Will be 3.42 gears.
Old Jan 29, 2007 | 09:33 PM
5678TA's Avatar
Car: 1984 Trans Am
is it a 350 or 383??
Old Jan 29, 2007 | 09:44 PM
redlsone's Avatar
actually its a 385ci.
Old Jan 29, 2007 | 09:57 PM
5678TA's Avatar
Car: 1984 Trans Am
385, NICE.. me too.. ok sorry but more questions.. tell me more about the motor.. forged bottom? compression ratio? hydraulic or solid flat tappet cam or hydraulic or solid roller?? how high of an rpm would you go??
i dont know about the stall on the converter.. i only run a manual..
Old Jan 30, 2007 | 03:21 AM
redlsone's Avatar
Its a solid rolller,compression about 10:1 about i believe would rev till 6500.
The converter is a tci 3000.
Old Jan 30, 2007 | 11:32 AM
5678TA's Avatar
Car: 1984 Trans Am
here is a summit comparison page.. its all the solid rollers with peak RPM from 6500-7000.. happy hunting.. i probably wouldnt choose the ones that go to 7000.. duration is a bit high.. dont think you have the compression for it.. probably the ones that go to 6500 or 6600..
http://store.summitracing.com/compar...=KeywordSearch
Caspar
Jun 19, 2016 11:19 PM
blackroc68
Sep 1, 2015 08:01 PM
midge54
Aug 29, 2015 09:51 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Jake_92RS
Aug 17, 2015 09:42 AM
