Smoking Spark Plug
Old Feb 7, 2007 | 11:13 AM
ecuxc's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Smoking Spark Plug
Hi All,
I recently changed my spark plugs with replacement AC Delcos gapped to .035". I started her up and the engine ran perfectly fine except once she started to warm up, cylinder # 4 started smoking from the spark plug. It appeared that the plug was red hot. I checked the connections and everything seemed fine. I have also performed a search on this but cannot figure what the problem could be. Could the gap be off or debris in the cylinder? I wouldn't think it would be the gap because this would mean either too much spark or not enough. This does not make much sense to me. Any thoughts?
I forgot to mention that when the accelerator is pressed there does not seem to be much power and more gas must be given.
Thanks,
Matt
Old Feb 8, 2007 | 12:07 PM
82_t/a_305's Avatar
Car: 1982 Trans Am
Engine: 305 H.0
Transmission: th350
check the spark plug gap , i think its .040" on stock motors
Old Feb 8, 2007 | 12:48 PM
Damon's Avatar
You sure you have the right kind of plugs in the motor? Gasketed seat plugs won't work in a tapered-seat cylinder head or vice versa. They won't seal up and the combustion gasses will start pushing past them, eventually overheating the plug.
Also, make sure you've got the right wires going to the right plugs. Won't run worth a damn with 2 wires mixed up.
Old Feb 8, 2007 | 01:39 PM
Mitre#136's Avatar
Car: 88 Pontiac Trans Am
Engine: 5.0L
Transmission: 4spd auto model unknown
That's true, I once mixed two wires up and I experienced your same symptoms, it sounds like it's worth double checking....
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Gunsbee
Sep 7, 2015 07:10 PM
L0tuS
Sep 4, 2015 11:16 PM
