help heater box removal.
Old Feb 7, 2007 | 04:30 PM
1987camarosport's Avatar
Car: Camaro
Engine: worked 350
Transmission: automatic
Axle/Gears: 3:73
hey all i went to a pick a part place today and found one camaro w/ a ac delete box i got all the top screws off and cant for the life of me figure out how to get the 2 screws from the bottom they looks lke they are from inside the car? If you are standing infron of the car one looks to be at appx. 4 oclock and the other 8 o'clock, how do i remove them. do i need to remove the dash if so im jst gunna forget ir and nor run heat in the car.. any help is great
Old Feb 7, 2007 | 04:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
They're relatively easy to get to from inside the car.
Old Feb 7, 2007 | 05:06 PM
deadtrend1's Avatar
at the most you may need to pull down the lower cover on the dash, but just pull the carpet back and you'll see them.....
Old Feb 7, 2007 | 05:52 PM
Car: Camaro
Engine: worked 350
Axle/Gears: 3:73
DO i need the heater controls to make this work properly? Its not big deal if i do ill just take that out also.. this car also had a speaker delete panel on the sail panel but some1 put speakers in ...there anything else i should snag outa there while im in there.
Old Feb 8, 2007 | 04:29 PM
Car: Camaro
Engine: worked 350
Axle/Gears: 3:73
OK i got the heater control from the junked car are the rods in the back the same as mine? and what about the wiring i cut the junked cars harness so i can splice mine. or can i just use my heater control and re work the wiring a little bit
Old Feb 8, 2007 | 04:32 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The vent arrangement in a non-A/C car is quite different from an A/C car. if you wanted to do a complete swap you'd end up replacing the entire dash. It's probably easiest just to leave your A/C controls in place.
Old Feb 8, 2007 | 05:41 PM
Car: Camaro
Engine: worked 350
Axle/Gears: 3:73
alright ill just wire up the controls from my unit to the new box. does anyone know what wires go to what as far as controler to motor?
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
