Anyone had their 305 dyno'd?
Old Feb 8, 2007 | 08:30 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Hey everyone.
Im planning a trick set up for a 305 i have (trick in my mind atleast).
Im just wondering if anyone here has had their 305 dyno tested, what results did you get? What were the modifications?
My plan is:
89 305 block
Stock rotating assembly
Hypereutectic pistons (no overbore)
HV oil pump
LT1 Cam
Double Roller Timing chain
Modified LT1 Heads (to fit Gen1)
Modified LT1 Intake (to fit gen 1)
airfoil on TB
Edelbrock TES headers
3.42 rear
1.6 Roller Rockers
Anyone have ANY idea of what kind of power that would put down? i have the heads being machined in my tech class at school, and im going to do the intake next. Ive already got the headers on my car, cam in the engine, etc.
Just wondering if anyone has any idea of power output. the heads flow about 20cfm better then the 113 castings in every point of lift, and im 100% sure the intake will flow far better then the stock TPI
Thanks everyone!
sheldon
Old Feb 8, 2007 | 08:47 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
nm. i misinterpreted this post.
Old Feb 8, 2007 | 08:52 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
The heads and intake are a project at school, im getting marked on how well i do them, and figured i could get good marks and go fast
Old Feb 8, 2007 | 09:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You don't need the HV oil pump. What's the point of changing the pistons?
Old Feb 9, 2007 | 06:32 AM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
HV oilpump and Hyper. pistons come with the rebuild kit i would be using that also includes bearings, rings, freeze plugs etc
Old Feb 9, 2007 | 09:41 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
No overbore? Your'e just going to hone the cylinders?
Old Feb 9, 2007 | 10:01 AM
What's the "baby LT1"?
I'd think dyno numbers for that would give a rough indication of what to expect. Although I don't know that anybody every dynos those, they just throw them away and get a full-size LT1 if they care about making power.
Seems like an AWFUL lot of maze to run, with very little cheese as the prize.
Old Feb 9, 2007 | 12:10 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Thanks for the input everyone.
Im thinking i will pull the plug on this project, and just drop a real LT1 in with a few bolt ons.
I think i will find its cheaper that route, seeing the LT1 4th gens are getting near the L98 3rd gens, i will just look for a wrecked LT1 car, and do a swap.
I have seen plenty of LT1's dyno 300rwhp, with just LT headers, bigger TB, some porting, ignition upgrades, a cam, and rockers.
My 305 should dyno about 200rwhp as it sits now with my new cam, headers, ported parts etc.
Sheldon
Hotrodboba400
Dec 10, 2019 07:07 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
Stryker412
Sep 7, 2015 09:11 AM
willyjoejr
Sep 3, 2015 09:26 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
