SCANNER CODES.... OMG!!
Old Feb 8, 2007 | 11:01 PM
Superman04's Avatar
Car: Camaro
Engine: V8
Transmission: Automatic
Axle/Gears: Stock
Well my car has been running like pure crap lately and I did a complete tune up and it still ran the same. So I decided to scan the computer for error codes and these are what it read:
Code
22 - Throttle Position Sensor Too Low
32 - EGR System Problem
34 - MAF Sensor or Circuit Too Low
42 - Electronic Spark Timing (EST) Problem
43 - ESC Module or Sensor Problem
52 - CALPACK Missing or Improperly Seated
53 - System Voltage Too High
The TPS reading was 0.58 and the IAC was 145.
I think most of you would agree that these codes probably have something to do with why my car is running like crap. Where should I start? Also, what is a CODE 52 Calpack Missing or Improperly Seated? I don't even know what a "calpack" is.
Could someone please advise me as to what steps I should take next. Thanks
Old Feb 9, 2007 | 01:12 AM
Vader's Avatar
Solve the 52, and most of the other problems might disappear. I'd suspect connections in or at the ECM first.
The CALPAK is also known as a MEMCAL. It is inside the small cover on the ECM:
Old Feb 9, 2007 | 08:03 PM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
look for a bent pin on your memcal. If you find one fix it then clear your codes and recheck.
Old Feb 9, 2007 | 09:46 PM
Superman04's Avatar
Car: Camaro
Engine: V8
Axle/Gears: Stock
so i'm guessing that having a bent or dirty connection could make the car run like absolute crap? i had the computer replaced about a year ago and it worked fine up until now. i think they used the old memcal chip and just intstalled a new ECM. i hope it still has a warranty.
Old Feb 9, 2007 | 09:50 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
right. If the computer doesnt see the memcal, it goes into failsafe (limp home) mode. Do you have an SES light flashing?
Old Feb 10, 2007 | 09:53 AM
Superman04's Avatar
Car: Camaro
Engine: V8
Axle/Gears: Stock
the SES light was removed because it was always on because the EGR was missing, but yes, the light is on. the car sure does run like it's in limp mode. it's limping that's for sure, lol
Old Feb 10, 2007 | 10:02 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
When I put my car in limp mode the SES light was just on steady, not flashing.
Old Feb 10, 2007 | 06:47 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
the rule myself and lot of my mechanic friends follow for older computers on cars..if you get more than 4 codes....try another computer.....
Old Feb 11, 2007 | 01:55 AM
Superman04's Avatar
Car: Camaro
Engine: V8
Axle/Gears: Stock
the car electrical place that installed the computer is closed until monday, so ill have to wait to see if this ECM still has a warranty from a year ago
Old Feb 14, 2007 | 05:04 PM
Superman04's Avatar
Car: Camaro
Engine: V8
Axle/Gears: Stock
i guess the 85 camaro's have two calpacks and my car was missing one of them. replaced it and now it runs like new. especially good after the tune-up. thanks to everyone for the help and info on the subject. keep rockin!!
Rousseau92maro
Feb 1, 2016 05:12 PM
whtltng89
Sep 8, 2015 07:06 PM
Electro_X
Aug 19, 2015 07:59 AM
mizz0313
Aug 12, 2015 06:45 AM
RARE-ROC-Z
Jun 25, 2001 01:06 PM
