L98 113 heads
Old Feb 9, 2007 | 07:37 AM
8996chevy's Avatar
Car: 89 IROC
Engine: 355
Transmission: 5 sp., Alum Driveshaft
Axle/Gears: 3.73 Posi
L98 113 heads
On an l98 113 head, are the rocker studs pressed in or are they screwed in, and if screwed in, are they 3/8 or 7/16? also, can the corvette magnesium valve covers be polished up to shine like aluminum and hold their shine? thanks
Old Feb 9, 2007 | 07:54 AM
Screw-in
The heads are 7/16"
Probably, if you clear-coat them; if left bare they'll corrode just like aluminum does
Old Feb 9, 2007 | 08:51 AM
Damon's Avatar
The bottoms of the studs where they screw into the head are 7/16" but the tops where the rockers slide on are 3/8", if my rapidly aging memory is correct. i.e. you need rockers designed or 3/8" studs.
lt500r55
Sep 1, 2021 01:30 PM
CRFred
Feb 7, 2016 11:39 PM
italiano67
Aug 31, 2015 06:04 PM
TheExaminer
Aug 19, 2015 10:07 PM
anesthes
Aug 8, 2015 09:37 PM
