TPI 350 from a TPI 305
Old Feb 11, 2007 | 04:19 AM
lugnut's Avatar
Car: 1970 chevelle
Engine: Lq4 408
Transmission: th400
Axle/Gears: 3:73
Hey,this should be a no brainer im sure,but how can I be for sure im getting a 350 TPI if its out of the car,where are the #s what are they,what to look for.DO they have 5.7 on the 350 block,thats what im thinking,if I remember,thanks
Old Feb 11, 2007 | 04:42 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Remove a valve cover. Look at the casting number cast on the top of the head. 350L98 TPi cast iron heads the casting number ends in 083. the 305 TPi head ends in 081.
191 or 193 is a swirl port head from a low perf TBI motor.
Neither are right for either TPI motor.
Aluminum L98 350TPi heads end in 113
Old Feb 11, 2007 | 01:40 PM
lugnut's Avatar
Car: 1970 chevelle
Engine: Lq4 408
Transmission: th400
Axle/Gears: 3:73
excellant,thanks!!
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
