If I took my stock 305 out and had some time to work on it...
Old Feb 15, 2007 | 03:23 PM
PRLirocz85's Avatar
Car: 1985 Camaro IROC-Z
Transmission: 700r4 (rebuilt)
Axle/Gears: stock
...what all could be done under a reasonable budget as an overhaul? I'm definitely an amateur, just doing this as a hobby. I'm considering doing this as more of a learning experience than anything else, but of course I'd like my car to run faster & better as a result. Keep in mind that I'm just tossing this idea around in my head, because I think it would be better to start off slow like this rather than just have an engine dropped into it & not learn anything about it. New headers, lifters, cam, gaskets, hell... even new pistons. Whatever you think. I just want some helpful opinions and advice. So what do you guys think?
Old Feb 15, 2007 | 03:30 PM
atc3434's Avatar
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
Well, if you wanna learn, why not go through a rebuild kit. Maybe do a little bit hotter cam, port the heads, or maybe get a set of 350 vortec heads milled down to 58cc. Slap a full exhaust on there, and get the top-end ported if keeping TPI is your thing. That'd help you learn plenty, and a vortec headed 305 can be pretty stout.
Old Feb 15, 2007 | 04:25 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Don't do pistons. If the cylinders are worn to the point that it needs to be bored out and new pistons installed, go find a 350 shortblock and work with that instead. Seriously. It'll be no more expensive, and possibly cheaper, and the results much more rewarding.
The heads are decent parts. You could take them to a machine shop and have a basic rebuild done on them, with new valve stem seals and new valve springs and retainers. Or, you could have the shop machine them for 1.94" intake valves, do a port clean-up job on them, then have them put together with new 1.94" intake valves and the above seals & springs. They could go back on the still-okay 305, or the newly aquired and rebuilt 350.
Then, cam, lifters, headers, gaskets. If you are feeling your oats, a new intake manifold. Certainly a better air cleaner than the stock single-snorkel.
Old Feb 15, 2007 | 04:31 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
haha, deja-vu?
This sounds exactly like my first post here on TGO
https://www.thirdgen.org/forums/tech...st-honing.html
I ended up just getting a 350 and doing a semi budget build up on it. Very rewarding experience for sure. It's tough wrecking something due to your inexperience, so doing a cheap motor is a good thing, you have less $$ in it in case something is pooched. *cough* like a cam wiping out *cough*
Old Feb 15, 2007 | 06:37 PM
PRLirocz85's Avatar
Axle/Gears: stock
Cool, thanks for the info guys. Anything else I need to look into? Any books or guides or anything?
Old Feb 16, 2007 | 12:26 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Originally Posted by Sonix
haha, deja-vu?
I'm glad to hear that your cough has cleared up! Seems to me that it was a pretty bad one....
Old Feb 16, 2007 | 02:06 PM
Sonix's Avatar
Car: 1982 Trans-Am
yea, it caused a nervous twitch and a short term bout of tourettes
"How to rebuild your SBC" by vizard is a good rebuild book. Shows lots of pictures, and lots of little things that ideally your experienced helper would be showing you. So when that experienced helper does not exist, the book is golden.
Old Feb 16, 2007 | 05:53 PM
PRLirocz85's Avatar
Axle/Gears: stock
Cool thanks. I'll check that out. Probably a stupid question, but what's an SBC?
Old Feb 16, 2007 | 05:56 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Small Block Chevy
Old Feb 16, 2007 | 06:01 PM
Sonix's Avatar
Car: 1982 Trans-Am
Small Block Chevy. Such as a 305, 350, 383, 400, or all the other older combinations that you probably won't be running across.
Old Feb 16, 2007 | 06:36 PM
PRLirocz85's Avatar
Axle/Gears: stock
Ahh, gracias. I should have known that.
Old Feb 16, 2007 | 06:39 PM
grumpyvette's Avatar
https://www.thirdgen.org/forums/tech...ing-books.html
Old Feb 16, 2007 | 09:53 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
for like 10 bucks theres a dvd on ebay of guy who goes through a 350, and rebuilds it. I bought it when i bought my car, and seriously its very helpful cause you actually see someone doing it.
Azrael91966669
25
Jun 20, 2017 04:04 AM
NBrehm
Aug 25, 2015 11:49 PM
marcusaw
Aug 10, 2015 08:13 AM
Leggman1
Aug 6, 2015 04:15 AM
