o2 and o2 signal wire length question
Old Feb 16, 2007 | 12:34 AM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
I installed a denso 4-wire o2 a few weeks ago. 95% of my hesitation problems went away, but it still drinks too much gas.
When I hooked the wires up, I didn' cut the signal wire and it's about 1.5 to 2 inches longer than stock I think. The connector was crimped on nice and tight with a bit of solder.
Would that extra bit of wire length be enough to effect it?
Also, does the o2 need to be specific for the computer, (as a few people have told me) or does any universal heated o2 work? (as I remember reading here)
I sorta suspect a vac leak somewhere too, as that's what my symptoms suggest, but I doubt I'll find one when I check the system this weekend.
Old Feb 16, 2007 | 06:18 AM
Damon's Avatar
As long as the connection is good, a few inches in wire length won't matter.
I have used 3-wire heated O2s before replacing the factory unheated O2. I think the X-reference I used was for a 93 Corvette. You need a signal wire and 2 more wires for the O2 heater. Not sure why you would need a 4-wire sensor, but I'm not an O2 sensor expert.
midge54
Dec 27, 2019 04:14 PM
Caspar
Jun 19, 2016 11:19 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
