'86 T/A S/E 2.8 V6 New Engine, No Spark
Old Feb 21, 2007 | 03:17 PM
Birdsong_'89_RS's Avatar
Car: '90 Camaro RS, '94 Miata, '95 F-250
Engine: 5.7 TBI V8, 1.8 PFI L4, 7.5 PFI V8
Transmission: 4L60-OD, 5spd Std, 5Spd Std
Axle/Gears: 2.73 Posi, 4.10 LSD, 3.55 Posi
I just replaced my T/A 2.8 litre V6 with a new one from Scoggin Dickey, I think I've got all of the wires hooked up, and it's got no spark and it also keeps burning out my gauges fuse.
Old Feb 24, 2007 | 10:11 PM
Just put in a new pickup coil, iginition module, coil, plug wires, plugs, distributor cap, and rotor, only has fire when I twist distributor, has a blue spark at coil. I had engine running three days ago, but I had to redo the intake cause it was leaking water into the oil. It will fire if I twist the distributor, but if I try to spin the engine over, it won't fire. PLEASE HELP!
Old Feb 24, 2007 | 10:30 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
im not very farmiliar with v6's But if your spinning the distributor your changing the timing, Are you sure your not 180 degrees of from tdc?
Old Feb 26, 2007 | 09:48 PM
I Checked firing order, its close enough to start.
This is my first run-in with a MPFI car, and don't really know much about multi port, I'm pretty good with Throttle Body and I'm almost an expert with a 4 brl after 6 years of circle track pit work and 2 years racing my Street Stock.
I had my freind spin the engine over and I touched the tip off the coil with my fingers and did not get shocked. Then my freind held the tip of the coil while I twisted the distibutor. In Short, He got shocked, every time I moved it. sad and painful way to check for fire
This really p***es me off, cause i had it running till I redone the intake.
I fixed the gauge fuse problem, I'm not sure what I did, but it stopped poppin'
Old Mar 2, 2007 | 12:19 PM
It's got fire now, the coil wasn't grounded enough were I had it I guess. I found out the hard way it had fire too...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
bjpotter
Oct 4, 2015 07:48 PM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
rjcme
Sep 5, 2015 01:23 PM
