Comp 280XFI info needed
Old Feb 21, 2007 | 11:03 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
I know the duration, lift, and stuff like that but what I need to know are:
1) Idle characteristics in a 350 and 383....sound clips would be great.
2) Do you need a vacuum assist for the brakes and how much vacuum does it pull?
The combo I'm thinking about is:
383 with 10.5 compression
AFR 180cc heads(need the torque for the truck)
280 XFI hyd. roller
HSR with deburring/polished runners
58mm TB
32 lb/hr injectors
however, I might have to go 355 if funds don't permit for the 383.
Thanks for the info.
Old Feb 21, 2007 | 11:07 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I don't have it in a 350-383, but in a 305, well 312. Idles with 12-14 in/hg of idle at 750 rpm.
http://youtube.com/watch?v=6XLXwAXkDHo
Old Feb 22, 2007 | 01:36 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Thanks Fast.....doesn't sound like a bad idle at all in your 312. Should sound mean in a 383 then.
The brake assist is what I am more worried about....keeping the vacuum up enough.
Anyone else?
Old Feb 22, 2007 | 02:34 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
x
Old Feb 22, 2007 | 05:30 PM
Guest
Guest
Posts: n/a
No problem with brakes here. 350 TPI. I think I'm pulling around 10-11 at idle these days. Was less but I've changed the tune quite a few times. I'd consider some larger heads or a smaller cam though, doesnt sound like a good match to me.
http://home.earthlink.net/~chris.foster/GPrev1.wav
Old Feb 22, 2007 | 10:29 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
I've thought about the 230/236 cam on a 112 with .510 lift but no one has done anything really with the 180cc and I am curious of the potential out of them. Will they be a restriction, probably not considering they flow good but if they are holding me back, I'll upgrade to the 195cc. Not a big deal to me. I like trying new things. If people are getting the power out of a 170cc vortec head then a 180cc AFR head should be fun.
Old Feb 22, 2007 | 11:24 PM
Guest
Guest
Posts: n/a
Just looking at the intake and cam, with a 383, the heads arent ideal but sure they'll make decent power. Good pick on the CR though, thats about what I'd shoot for with that combo on a street car.
Old Feb 23, 2007 | 09:38 AM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Yea, I know what you mean about the heads but there great for torque. I would just like to know what there potential is and when does it become a restriction. They are actually like a 185cc if I remember correct from an article that was written about AFR so.....we shall see. The HSR port and 180cc port is an exact match so that's not a problem as I see it. But like I said, I would like to know the potential for these heads and switch later if I have too. Not a big deal to me b/c I always like to change things if I'm not happy with them.....plus, I already have them on a existing engine in the truck so....they are here for the picking and I don't have to spend money on them.
Old Feb 26, 2007 | 08:06 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Going up for any more information.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
TreDeClaw
Aug 14, 2015 06:58 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
