Help, snapped bolt
Old Feb 22, 2007 | 11:49 AM
BuiltZ28's Avatar
Help, snapped bolt
A repost from the trans/drive train from, cant seem to get any replies over there.
Just putting together my 388ci/700r4 combo, a warm day in the northeast had me back at it.
Wanted to finish up the bellhousing bolts. Luck has it I snapped the driverside lowest bolt.
Im really not looking forward to pulling the engine and trans again to remedy this.
I plan on pulling the 700r4 next winter to have it beefed up (I cant imagine the stocker holding behind this motor very well)
Do you think the 5 bolt will hold aright for a season or shall I pull the drivetrain again?
Kyle
________________
Old Feb 22, 2007 | 12:20 PM
brians88gta's Avatar
Car: 88 gta
Engine: 350 HSR
Axle/Gears: 3:27 borg warner 9 bolt
if ur gonna pull the motor again then i would leave it
Old Feb 22, 2007 | 12:36 PM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
Some people do get by without 1 bolt in it, usually the top bolt on the bellhousing/engine. Personally if its a half a$$ed job then who cares, but for my car I would rather have all bolts in, so one of those "just in case" moments doesn't occur. So, IMHO do it right or dont do it at all.
Old Feb 22, 2007 | 05:41 PM
BuiltZ28's Avatar
So what your saying is that the bottom bolts are more crucial then the top.
I read on here somone saying that the pins in fact take most of the force. Is this valid at all?
Kyle
Old Feb 22, 2007 | 06:22 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
This is true, when the bolts are tight. I have known people who have run transmissions with one or 2 bolts missing. The problem becomes: you can't keep the rest of the bolts from loosening over time no matter how tight they are put in. When they back out, witness the "bellhousing explosion".
Old Feb 22, 2007 | 06:29 PM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
if all the other bolts are tight and you dont beat on it it should be ok. but if the other bolts come loose you take a chance of cracking the bellhousing and wasting it. if its the lower bolt i have gotten them out by loosening all the other bolts just enough to get a pair of needlenose plires between block and bellhousing and backed out the broken bolt. as long as you didnt use to long of bolts and bottomed them out in the block.
F-body driver
Mar 6, 2023 11:44 AM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
billybob6110
Sep 23, 2015 01:30 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
