Hard to start (hot) after new injectors installed
Old Feb 22, 2007 | 04:36 PM
Rayvan's Avatar
Car: '89 Formula WS6 N10 No T-Tops
Engine: LB9 225HP
Axle/Gears: 3:45BW
Anyone ever heard of this?
Recently Replaced my injectors with some 19 lb. Accel units and now the car is hard to start warm (and hot). Gotta crank it about 4-5 seconds before it lights up...
Did full tune-up, didn't help. Replace 02 sensor, no help.
Car had no problems starting while hot with the stock injectors even though two of them mearured out-of-spec....
Fires right up when cold
Car is a bone stock '89 TPI LB9 Dual-cat 5 speed Firebird Formula (no cold-start injector) that I bought brand-new.
Thanks, Rayvan
Old Feb 22, 2007 | 08:04 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
maybe they are a bit leaky, that would explain the good startup in cold and poor warm/hot starts...
Old Feb 23, 2007 | 11:29 AM
Rayvan's Avatar
Engine: LB9 225HP
Axle/Gears: 3:45BW
Thanks for the reply.
Thats what I thought at first, but the system seems to hold pressure. If I press the schraeder valve, even after a week of non-use, there is still good pressure on the fuel rail.
Old Feb 23, 2007 | 12:36 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I would get a fuel pressure gauge and watch how quick the fuel pressure drops off after the car is turned off.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
drathaar907
Aug 6, 2015 04:20 PM
