stalling issues only when a/c is on
Old Feb 22, 2007 | 08:51 PM
gordo420's Avatar
Car: 89 RS Camaro
Engine: 355ci.
Axle/Gears: 373:1
I am at a loss when trying to figure out the problem, with the A/C off there is no issue, 305 TBI runs fine, I just had the A/C system replaced for the up comming South Florida summer season, and when I turn it on when engine is cold it will run fine but after the engine is warmed up it would stall after coming to a stoplight, I cleaned the IAC motor but thats it.
any input would be very helpful, also i seached all stalling issues in the search critirea.
Thanx
Old Feb 22, 2007 | 10:32 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
when the AC system was replaced did they put the proper amount of oil in the compressor? when the A/c is on the electric clutch on the compressor cycles if there isnt oil it can defenitly stall the engine
Old Feb 23, 2007 | 04:53 AM
gordo420's Avatar
Car: 89 RS Camaro
Engine: 355ci.
Axle/Gears: 373:1
yes they did, I went to a buddy of mine and he is good at what he does, I have worked with him in the past, so I know he did a good job, I was there for the instal as well.
out of pocket with replacement of compressor, accumilater, orricace, oil, r124,and labor came to $250
Old Feb 23, 2007 | 05:21 PM
gordo420's Avatar
Car: 89 RS Camaro
Engine: 355ci.
Axle/Gears: 373:1
anyone else?
Old Feb 23, 2007 | 05:59 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Is this a modified 355 underneath the stock 305 TBI setup?
Old Feb 23, 2007 | 06:42 PM
gordo420's Avatar
Car: 89 RS Camaro
Engine: 355ci.
Axle/Gears: 373:1
woops I am getting ahead of myself here I need to change it back to 305 TBI I was going to intal the motor in but hit a snag so it would have to wait
Frozer!!!
Jan 19, 2024 04:55 PM
jklein337
Sep 19, 2018 06:23 PM
777Shock777
Oct 29, 2015 04:30 PM
Bryan F
Aug 18, 2015 02:28 PM
