LG4
Old Feb 23, 2007 | 06:25 PM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
LG4
Ok, I hear people talk about the "free" upgrades, what are they. Second I am blowing steam out the tailpipes. Losing coolant SO whats the problem.
Old Feb 23, 2007 | 06:45 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
well if you are blowing steam the head gaskets are leaking. time for a rebuild or upgrade.
Old Feb 23, 2007 | 10:40 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
or just time for a simple head gasket replacement
check spark plugs to find out which side of the engine needs the new head gasket
the water burning one(s) will be cleaner than all the rest
if too much water gets into a cylinder and the piston cant come up all the way due to the water then youll end up damaging the engine in a bad way
good luck
Old Feb 24, 2007 | 10:32 AM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
Its a LG$, its already in a bad way.
Old Feb 24, 2007 | 11:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Advancing the timing to about 6 degrees base (assuming this is a computer controlled US car, and not a Canadian-delivered car). Other than that, I don't know of any.
Could also be cracked heads.
RazorN8
Jan 7, 2022 11:44 AM
podiatra
Aug 31, 2015 09:53 AM
ambainb
Aug 29, 2015 12:43 AM
85ws6TA
Jun 27, 2001 12:25 PM
Conv389drv
Aftermarket Product Review
Dec 12, 2000 12:46 AM
