Do's and Dont's with 383
Old Feb 28, 2007 | 06:42 AM
Camarothatcould's Avatar
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
Hello all. I have a L98 that I'm taking to get a bore/hone, surface milling, cam bearings, and a stroker clearance. I'm just wondering what are the do's and dont's when I am building this motor?
I'm going with the Vortec heads. Going to grind down the valve guides so I can clear a bigger cam and quite possibly have the heads decked. Thats really all I plan to do with them.
What I'm asking here is if you had built a 383 stroker like I am about to, what would you take back?
I'm not sure what kind of cam or carb I am going to use, but I know I want a 12 sec street car.
The car itself has a 3.73 and a 700 trans.
So if any of you can give me some advice on building this motor with certain parts to make her really run hard, I'd like to hear them.
thank you
Old Feb 28, 2007 | 08:26 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
what rotating assembly do you have mind?
Old Feb 28, 2007 | 09:10 AM
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
http://northernautoparts.com/Product...ctModelId=1674
Old Feb 28, 2007 | 10:44 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Don't assemble anything without checking all the clearances at every step.
Old Feb 28, 2007 | 08:15 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Think very carefully about your camshaft choice. Be sure to measure everything you can while building it (it's harder to measure it when it's together ). Pay attention to your quench, and ring gap. None of this is stroker specific, but it's worth doing.
Old Feb 28, 2007 | 09:47 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
12's shouldn't be hard with the right setup. I built a vortec headed 383 for a customer last year that runs 11.80's in a 3500# TA. 6" rods, 10.7:1, stock vortecs with Manley valves and valve job, Air Gap intake, 750 DP, eagle crank and H beam rods, forged flat tops with metric rings, Comp 236/242. It made 470 at the flywheel. Should get you in the 12's pretty easy.
Old Feb 28, 2007 | 09:50 PM
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
470-? freaking sick!
I have a Edelbrock Performer intake. Not sure on a carb or cam still. Def roller cam though
Old Mar 1, 2007 | 09:22 AM
Dialed_In's Avatar
Keep in mind that's flywheel HP so it's going to be less than 400 at the wheels. As long as you choose the right combination of parts and put it all together properly you should have no problem getting that thing in the 12's. 11's is more like it Hope you plan on building a trans Mine lasted 2 passes and a couple hundred street miles before I cooked it with only 425 fwhp.
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
