86+ engines
Old Feb 28, 2007 | 10:56 PM
Cambridge205's Avatar
Car: 89 GTA
Engine: L98 350
Transmission: Swapped to a T-5
86+ engines
This could be a dumb question, but are all 86 and up V8 engines all roller lifter?
Old Feb 28, 2007 | 11:27 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
No.
'87 and up IIRC. Some of the TBI motors kept flat tappets actually, not sure when they swapped over.
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
All the 87+ engines used in F bodies are rollers. At first trucks had the same "roller" blocks but were equipped with flat tappet cams. Most of the truck blocks can take an OE roller cam with no trouble, but some of the early ones didn't have the necessary machining done.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
