oil leak timing cover
Old Mar 1, 2007 | 05:03 PM
Swim500in5's Avatar
Car: 83 Z-28
Engine: 305 Qjet
Transmission: 700r-4
so i have this timing cover problem, it wont stop leaking. any one ever have a problem with the 2 peice timing cover. brand new and leaking oil
Old Mar 1, 2007 | 05:28 PM
krly79's Avatar
Car: '93 S10 Short bed standard cab
Engine: 383 Stroker
Transmission: 92' stage 2 700r4 w/3600 stall
Yep. Mine was so bad I had to spear tons of gasket sealant around the bottom of mine before I put it on to fill the gap at the bottom. I'll be replacing mine soon, but had to do something in the meantime. It's due to the poor design. There are no bolts or screws at the bottom to seal it.
Old Mar 1, 2007 | 06:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Which 2 piece timing cover are you using?
Old Mar 1, 2007 | 07:09 PM
Swim500in5's Avatar
Car: 83 Z-28
Engine: 305 Qjet
cover
SUM-G3230
summit part number
Old Mar 1, 2007 | 07:16 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yeah, those ones aren't that great. The only two-piece covers that are any good are the billet ones like the Comp Cams 210, or the Summit equivalent G6312.
Old Mar 2, 2007 | 05:54 AM
Swim500in5's Avatar
Car: 83 Z-28
Engine: 305 Qjet
hmm, well im glad i bought it used and only paid $15
1992 Trans Am
May 10, 2023 07:19 PM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
bamaboy0323
Aug 15, 2015 07:20 AM
drathaar907
Aug 6, 2015 04:20 PM
