March Performance Electric Water Pump Bracket Problem
Old Mar 3, 2007 | 08:41 PM
Destructive099's Avatar
Car: Dark Blue 1987 Chevy Iroc-Z Camaro
Engine: 5.7 350
Axle/Gears: 3:42
First off March has greatly disapointed me in that after purchasing thier serpentine set for an alt and ps kit for an electric water pump and assembling it all, the alt worked fine however when I got to the power steering pump the 2 brackets didnt align correctly and was as if the pump had to be turned on the resivor however i dont believe this can be done, has anybody come up with any solutions to this or mods that can be done to get this setup to work ?
Old Dec 23, 2007 | 02:59 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: March Performance Electric Water Pump Bracket Problem
Did you ever get this fixed? what part number from march did you go with ? where does your alternator mount?
Old Sep 21, 2008 | 09:03 AM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
March disappointed me as well, I have a Meziere 300 series pump and the alternator spacer does not fit. I called up march and they said that the brackets were designed around the 100 series pumps and they are not sure if it would work... I ended up grinding aways at the appropriate spots to make the brackets work, but now I am having problems fitting a hose on to my waterpump with the bracket being so close...
Kinda disappointing spending close to 500 bucks on something and it doesnt work correctly...
Old Sep 21, 2008 | 09:35 AM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
i bought a serpentine swap from March and was totally 100% impressed and satisfied. one possible issue with your setups is that did you get the right kit for your waterpump (short or long style). that would definitely cause those issues that you all are having.
Old Sep 21, 2008 | 10:03 AM
Engine: 388 Carb
Axle/Gears: 4.10
With an electric water pump, the choice was CSI/ CSR or Meziere. I chose meziere. They did not inform me that they are unsure if it will fit a 300 series pump.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
