engine will not go further than 3200rpm
Old Sep 17, 2008 | 03:47 PM
FireTurdWS626's Avatar
Car: 1988 Firebird Formula WS6
Engine: LO3 305 tbi
Transmission: 700 R4
Axle/Gears: 3gen housing zexel torsen posi 3.42
I recently ran out of gas in my 88firebird (305 tbi 700r4) i refueled and started my way home, my car started to bog here and there but then just kept going good for 5 mins and then in would not want to go past 3200 rpm. is my pump mest up now or what other things could have happend when i ran out of gas?
please help me. thnx
p.s. could my egr valve be the problem? its in need of being replace also.
Old Sep 17, 2008 | 08:01 PM
85TAracer's Avatar
Car: 1985 Trans Am
Axle/Gears: 9 Bolt posi disc 3:27's
Re: engine will not go further than 3200rpm
What was it doing when it would only rev to 3200? did you try putting it to the floor at that time? did it backfire or pop or jerk and hesitate?
It seems that you may have sucked some crap into the fuel system somewhere when you ran out of gas, and filled it up and stirred things around. try replacing your fuel filter first.
Just my 2 cents.
tim
Old Sep 17, 2008 | 08:49 PM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
You could have clogged your fuel filter running it out of gas cause all the junk in the bottom of the tank goes to the filter with the last of the gas.
Old Sep 17, 2008 | 09:47 PM
Engine: LO3 305 tbi
Just my 2 cents.
tim
yeah when it would reach 3200 it would act like it would die so i'd floor it and it just struggles to stay at 3200 and jumps from 3000 to 3200. and i went out to show my buddy what i was talkin about and now it has trouble ideling
Old Sep 17, 2008 | 10:33 PM
Engine: LO3 305 tbi
was this the case for someone else's thirdgen?
Old Sep 17, 2008 | 10:49 PM
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
it's pretty common. Over years crap builds up on the bottom of the tank. When you run out it's trying to get that last bit and picks up all the dirt. Also when you poor more gas it stirs it up which also pumps all the dirt.
Old Sep 17, 2008 | 11:17 PM
Engine: LO3 305 tbi
cool thanx man well looks like I'm going to the parts store tomorrow.
oh hey my friend said if the filter was clogged the pump would burn out.
is this possible with my sistuation tho it was just like 15 mins of run time after i got gas?
Old Sep 18, 2008 | 08:19 AM
85TAracer's Avatar
Car: 1985 Trans Am
The pump will struggle to pull the right amount of fuel. the longer it is run like that the bigger the chance of burning it out. You should be fine.
Old Sep 18, 2008 | 08:48 AM
ezysk's Avatar
Car: 1986 Firebird / 1985 Trans-Am
Engine: 305 4BBL / 383 4BBL++
Transmission: 700R4 / 700R4
Axle/Gears: ?.?? / 3.47
I believe in almost every Firebird or Camaro I have picked up I notice one thing in common, at least on the TPI ones, no one seems to change the inline fuel filter that is under the car.
I just finished replacing the one on the last Firebird I picked up.
It definitely sounds like a fuel filter issue to me.
Take the time and replace it.
Your fuel pump will thank you for it.
Old Sep 19, 2008 | 02:03 PM
Engine: LO3 305 tbi
Hey guy just wanted to thank you a bunch for the advice, i just came back inside from changing it, and it purrs like a mountain lion now, thnx alot saved me the embarrassment of almost buying a fuel pump :-D
Old Sep 21, 2008 | 12:02 PM
Car: '89 IROC-Z
Engine: LSx
Good to here! Just try not to run it out of gas anymore
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
