Backfire when going to idle RPM
Old Mar 4, 2007 | 10:32 AM
87camaroPOS's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
Hey guys.
I just had a problem with my IAC today. I pulled it out and sprayed it down with Throttle Body cleaner. It got the car running, but now when I have the car revved to anywhere over 1,500 RPM and take my foot off the gas, I get a couple of quick little backfires out my exhaust. Could this problem be related to the IAC? Any ideas how to fix it?
Old Mar 4, 2007 | 12:15 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I dont think tha you can just pull the IAC out, I believe that there is a specific procedure on this. Also, what is your static timing? Sounds like a complete tuneup is needed.
Old Mar 4, 2007 | 01:13 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
well i would now say it is time to get a new IAC as solvent should never be sprayed on that...
xxx3man`
Sep 23, 2015 10:37 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
