Will this cam work good on my TPI
Old Mar 5, 2007 | 10:36 AM
hardcoreZcar's Avatar
Car: 86 Z
Engine: 400 sbc
Transmission: t-56
Axle/Gears: 4.10
Im building my 350 tpi project and it's time to buy the cam. I'm using iron heads with 2.02/1.60 valves and match porting. I have a MAF intake also with lower intake match porting. I also plan on custom programming. I want a good cam with lots of bottom end but am shooting for under $150 bucks. I found this cam for 140 on ebay. Do you guys think this stick will suit this engine well? Any suggestions? All comments are greatly appreciated. Thanks for the help boys. Third gen Pride!
.495 INTAKE LIFT / DUR.@.050 .218 DEGREES
.502 EXHAUST LIFT / DUR. @.050 .224 DEGREES LOBE SEPERATION IS II0 DEGREES
Old Mar 5, 2007 | 11:19 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You do not want any cam for TPI with less than 112 LSA.
Old Mar 5, 2007 | 11:56 AM
Nitsuj86Iroc's Avatar
Car: 86 Camaro Iroc-Z
Engine: 305ci TPI
Could I ask why not less than 112 LSA? what is it about the TPI?
Old Mar 5, 2007 | 01:10 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Is that the comp xe262hr? Well it has the advertised duration of a 262, I forget how the roller cams work like that. 260Hr?
The computer doesn't like overlap, 114LSA will make it run best. 112 will work. 110 is pushing the limits. That's why the "computer compatible" cams have 114 LSA's.
Old Mar 5, 2007 | 08:49 PM
Car: 86 Z
Engine: 400 sbc
Transmission: t-56
Axle/Gears: 4.10
That cam is also available in 112*. Will this give me good street performance and a good exhaust note? It's actually an LT1/LT4 cam but it will work work in all 87 up aside of the dowel pin right?
Not a comp cams stick.
Last edited by hardcoreZcar; Mar 5, 2007 at 08:51 PM. Reason: Automerged Doublepost
Old Mar 5, 2007 | 09:44 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I have a 110 LSA. It may not be ideal but I haven't had any issues with it.
camaro71633
Sep 1, 2015 10:24 AM
NBrehm
Aug 25, 2015 11:49 PM
squiggy2
Aug 9, 2015 09:30 PM
Fronzizzle
Aug 9, 2015 01:15 PM
drathaar907
Aug 6, 2015 04:20 PM
