Might be a stupid question...
Old Mar 5, 2007 | 02:04 PM
IROCZ_L98's Avatar
Car: 1987 IROCZ
Engine: 355, Vortec Heads, Carbed
Transmission: TH350, 2800 stall
Axle/Gears: 3.27 9 Bolt
Hello all...this may be stupid but would and engine kit for a 69-80 350 work on an '87 L98 350? I know the cam, lifters, valve cover gaskets, and rear main are different but are those the only differences? Will the bearings, rings, oil pump, timing chain, etc. be correct? I want to say yes but I just want to make sure before I order my kit. Thanks!
Old Mar 5, 2007 | 03:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The bearings, rings, head gaskets, intake gaskets, timing cover gaskets, front seal and oil pump would be the same. The timing set, cam, lifters, rear main seal, valve cover gaskets, and oil pan gasket will be different.
djmarch
Oct 2, 2015 10:41 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
83ho87gn
Sep 26, 2015 08:49 PM
spartanreaper
Sep 25, 2015 07:22 PM
83ho87gn
Sep 24, 2015 08:58 AM
