world products heads
Car: 1989 camaro rs
Engine: 305 tbi
Axle/Gears: 3.23 lsd swap
1.are all world products small block heads the same? i have a 305 and there is a set for sale in the local papper. world products S/R torquer heads, it says they are for a chevy small block. whell chevy small block doesnt really narrow it down. he wants 375 for the set.
2. is my engine a roller 305? how do you tell without removing the valve covers, my car is a 1989 LO3 rs
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
first off the there are 2 kinds of s/r torquers one set is for 305 engines, they have 1.94 / 1.5 valves, 58cc chambers and 170cc runners, the others have 67 and 76 cc chambers and 170cc runners. they are both about $760 per pair new. Your engine, and all 87+ engines are hydraulic roller cams, 375 sounds like a good price, plus you can still use your stock intake, otherwise i would reccommend vortec heads as they can be had for about the same price used or around $525 new but the intake must be swapped out.
evilstuie
Feb 28, 2016 03:33 PM
NinjaNife
Aug 23, 2015 11:49 AM
