LT1 Crank Snout Keypin or NOT
Old Mar 6, 2007 | 07:01 PM
zmack28's Avatar
I have done a serch and read about the LT1 crank snout keypin, everything I have read states that the LT1's did not have a keypin. Well when I went out to put my HUB onto the crank I noticed that there is a keypin on my crank. I know its a LT1 I ran the block numbers and it is a 96 LT1. I am now concerned about the crank......here is some pics of the crank snout, is this the way it should look???????
Old Mar 6, 2007 | 07:40 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
It wont hurt anything if it's not supposed to be there. Have a look at the inside of the hub. If there is a groove to accept the key then it needs to be installed. The LT1 crank is compatable with any other 1 piece seal crank. If the LT1 hub has no key way then chances are that it was rebuilt using an older crank which isn't necessarily a bad thing.
Old Mar 6, 2007 | 08:04 PM
zmack28's Avatar
So, how can i tell what crank was used and what should I do about the crank? Shoud I replace the crank or get a hub that matchs the crank??? Teh HUB DOES NOT have the slot for the key......thanks....
Old Mar 6, 2007 | 08:24 PM
Dialed_In's Avatar
I've never personally seen an LT1 without the key but I suppose anything is possible. Without it there is nothing to stop the hub/balancer from spinning on the crank.
Heres a pic I found on my computer from a while ago. Factory LT1 with a keyway.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
L0tuS
Sep 4, 2015 11:16 PM
