Removed interior, car won't start?????
Old Mar 3, 2007 | 12:13 PM
fbodfreek's Avatar
Car: 1990 Camaro Iroc-Z Convertible
Transmission: Automatic
I'm in the process of replacing my carpet and have the entire interior removed for the most part....console, carpet, seats, seatbelts, rear door panels, lower dash panels. I need to move it to make more room in the garage. The car turns over fine, but it's like I'm not getting any ignition. I've NEVER had a problem starting my car, even after months of storage. It's a '90 convertible. Any ideas?
Old Mar 3, 2007 | 12:43 PM
dan_o_89_rs's Avatar
Car: 89 camaro rs
Engine: 305 tbi
just a guess... but maybe it has something to do with your console being out. and your switches think you are stuck in a gear. but i think in my 89 if im in a gear it wont turn over at all. good luck.
ps- u didnt put a screw through a fuel line did you?
Old Mar 3, 2007 | 12:48 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
make sure something at the fuse block didnt come unplugged
check the fuses for ECM and FP and such
its gonna be something retarded
Old Mar 3, 2007 | 02:31 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Does the fuel pump prime when you put the key-on? You should be able to hear it nice and loud with the interior out.
Old Mar 3, 2007 | 02:48 PM
fbodfreek's Avatar
I'll check to see if the fuel pump kicks in. It turns over like a banshee, it's just like I'm getting no spark, like I've lost a ground or something. I may just wait 'till the interior's 1/2 assembled and see what gives.
Old Mar 3, 2007 | 03:16 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
I don't see what would give you a no spark by guttign the interior. Did you remove a ground wire that was somewhere by the drivers seat mounting area? There is a ground there. It doesn't look like much, but it is for the fuel pump.
Old Mar 5, 2007 | 10:44 PM
fbodfreek's Avatar
I bet that's it. I'll look tomorrow.
Old Mar 6, 2007 | 08:42 PM
fbodfreek's Avatar
...and the winner is?!?!? Well, I'm not really sure. I saw the ground you spoke of and it leads to the power seat, so I plugged it in and bolted the seat down...no go. I saw another ground attached to the driver's side seatbelt....no go. I saw a loose wire hanging under the dash, 'jiggled it' and she fired right up. I wish I felt more confident on exactly what it was, but it's running and that's what counts!! Woo hoo!!
Old Mar 6, 2007 | 09:52 PM
1989karr's Avatar
Engine: 3.4 / 5.0
hmmm....can I at least get half/partial credit to pass??? lol
Actually the one I was thinking of was a wire that comes out of the wiring harness that goes along the left side of the driver's floor and it bolts/grounds right by the front left seat bolt.
Anyway, glad to hear that you got it running. Any idea what that wire was?
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
3rdgenparts
Aug 8, 2015 07:09 PM
killer777
Aug 8, 2015 02:47 PM
