ignition key
Old Mar 9, 2007 | 06:48 PM
chicagopd50's Avatar
Car: 71 camaro, and also a 91 camaro
Engine: 383 stroker
Transmission: t5
Axle/Gears: 3:73 strange axle
ignition key
i took off my ignition key switch and want to put a whole new one all together, i dont want to use my old key with the chip on it.. does antone know what i should do with the security trip wires in the ignition switch.. should i cut them off or should i put them together????
Old Mar 9, 2007 | 07:27 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
you need the original key to measure the resistance in the pellet with a DVM then head to radioshack and purchase the correct resistor and wire it in line with those 2 wires...resistors can be stacked to get close... within 5-8 ohms depending
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
lanceflame44
Sep 25, 2015 12:28 PM
