Spark plug gap question
Old Mar 13, 2007 | 09:29 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Hope this is the right forum for this... Ok got a LO3, with Accel coil, cap, rotor, and wires with a new dizzy...My questions concerns plug gap,(AC DELCO) should I go with the stock gap, or open it up just a little??? My thinking is that since I have a bit more fire a little more gap would help....Any suggestions concerning this?????????? Also am curious about the Accel module (or aftermarket module in general) for the dizzy, is it a good idea?? I have always liked Accel product, so im not interested in changing any of this stuff just curious about the gap, and the module...Thanks for any help on this, Tom
Old Mar 13, 2007 | 09:53 PM
rosco88ta's Avatar
Car: 88 Trans Am
Engine: 355 c.i.
Transmission: 5 spd.
Axle/Gears: 3:42s
IMO I would use the stock gap on the plugs. since you don't have an ignition box you don't need to open them up anymore than stock gap.
Old Mar 13, 2007 | 09:56 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
.045 is plenty, if you want to do anything then get longer tip plugs(X suffix in the part number for ac delco anyways)
i always use the X tip plugs because it puts the sparkinto the chamber farther and they take up some volume too
get 8.8 wires
a performance module or a GM 454 one
and make sure your advance curve is good for your engine and modifications
good luck
Old Mar 13, 2007 | 10:11 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
An ignition box huh..????...Well I know the next year or the year or 2 later the factory spec were a little wider.......Thanks, Tom
evilstuie
Feb 28, 2016 03:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
Bryan F
Aug 18, 2015 02:28 PM
