Trans Oil Filling
Old Mar 14, 2007 | 09:34 PM
chicagopd50's Avatar
Car: 71 camaro, and also a 91 camaro
Engine: 383 stroker
Transmission: t5
Axle/Gears: 3:73 strange axle
Trans Oil Filling
hi guys, just rencently bought a new clutch kit , and had the tranny on the jack, after i finished installing the clutch kit, i tried installing the tranny, it was on an angle and spilled out fluid from the back part, where the drive shaft sits.... i finally installed the tranny but there probably is no fluid, was wondering if anyone knew exactly how to fill a borg warner t5 with fluid... thank you much guys, any help is appreciated....
Old Mar 15, 2007 | 05:32 AM
Assemble car completely; remove fill plug (about halfway up the case on the pass side); insert fluid.
Old Mar 15, 2007 | 04:39 PM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
I removed the shifter on top and poured it in from inside the car (till it poured out the top hole).
maroe624
Apr 16, 2017 08:29 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
Leggman1
Aug 6, 2015 04:15 AM
