Pushrod Problem
Old Mar 15, 2007 | 09:06 PM
92KRVZ28's Avatar
Car: 1992 25th Anniversary White W/ Red
Engine: Procharged 383CI/ Soon LS2 Turbo
Transmission: Manual 700R4
Axle/Gears: 4:11/Auburn Posi/Moser Axle
Pushrod Problem
I have Dart Iron Eagle Heads
Comp Guideplates
Scorpion 1.5 rockers
The nut is hitting the ends of the rockers, which would be because the pushrod is too small. Anyone have a set up like this, and what rod are you using. I bought a rod checker today and it seemed as though a rod i had out of my 93 pick up with a 350 fit perfect, but yet it isnt hydraulic roller. Anyone have any advice i cant seem to figure this out.
Old Mar 16, 2007 | 07:04 AM
Well there's about .400" of difference between the push rods in a factory roller motor and a non-roller one. That's HUGE.
Sounds to me like you should use whatever works. If roller ones don't work and non-roller ones do, use non-roller ones (7.8", more or less; compared to 7.4" for roller ones). Also sounds like you don't have a roller setup in your motor.
Old Mar 16, 2007 | 09:31 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
I thought the roller ones were 7.2?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
