HELP: weird engine knocking syndrome
Old Mar 16, 2007 | 03:51 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
I just got my new engine swap (1989 5.0 TPI with 20,000 miles rebuilt) running. I noticed something very distressing... The engine seems to be knocking. However, the sound COMPLETELY disappears if I open the oil cap or remove the passenger side PCV.
Oil pressure is about 40 psi idling at 700 rpm.
It has been making the sound since I first started it. Disconnecting spark advance has no effect.
Total run time, about 30 minutes, on and off since last week. Up until today I thought it was the severed A.I.R tubes making the noise, but I test capped them and the noise remained. I then opened the oil cap to see how much oil was making it to the rockers and the noise vanished...
HELP
Brendan
Old Mar 16, 2007 | 04:09 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
you do have a breather in the other cover dont you?
Old Mar 16, 2007 | 04:13 PM
Toehead's Avatar
It actually looks like 2 pcv valves. One is connected to the lower intake under the plenum.(the driver side one) The passenger side one has a pcv valve in it and is connected (now) to the no vacuum port on the TB. I'll go check to see if the other is also a pcv valve.
Old Mar 16, 2007 | 04:23 PM
Car: 91 RS
Engine: 350 vortec
no you have it right it looks like a pcv but it is just a vent should be on passanger valve cover at the back
Old Mar 16, 2007 | 04:26 PM
Toehead's Avatar
It IS two pcd valves. It was like that when I got it, I assumed the passenger side was just a breather....
Can having two pcv valves installed cause that sound?
Did it damage anything?
They are at the center of the valve covers.. I took them both off, and they are both pcv valves... I tried blowing through them to be sure.
Old Mar 16, 2007 | 04:32 PM
Car: 91 RS
Engine: 350 vortec
sure could if you remove the oil cap and the noise stopped
Old Mar 16, 2007 | 04:36 PM
Toehead's Avatar
I suppose that's true....
I really want to understand WHY the noise happened, and what i was. I understand that the crankcase pressure was all out of whack due to the lack of a breather.... I really just want to make sure that it didnt hurt anything.
Old Mar 16, 2007 | 04:40 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The PCV valve in the breather side would have kept fresh air from entering the crankcase, so the PCV valve on the other side would have been putting the crankcase under vacuum. Opening the oil cap or removing the breather would have allowed air in to equalize the pressure.
Car: 91 RS
Engine: 350 vortec
i could tell you but it would only be a guess and it wouldnt be good... but for only 30 minutes i dont think it could have caused any damage
Old Mar 18, 2007 | 10:12 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
I think the pressure pulsations maybe were causing the oil pan to
"oil-drum" (sheet metal popping in and out). It shouldn't have hurt anything since the crankcase would have had negative pressure on it.
I had one engine we had built knock loud as hell when we put it back in only to find we had dented the pan very slightly and the crank counterweight was hitting it. It sounded like one rod had no bearings in it at all .
Old Mar 18, 2007 | 03:40 PM
one wheel peel's Avatar
Car: 84 camaro
Engine: 72 chevy 406 sbc
Axle/Gears: 3.42 eaton posi
dont laugh but i had put valve covers on upside down on wrong side once and lifter hit covers ,they are taperd slightly on one side.
Old Mar 18, 2007 | 04:50 PM
Car: 91 RS
Engine: 350 vortec
yeah those lifters shooting out of the bores are a menace...
Old Mar 19, 2007 | 10:05 PM
Toehead's Avatar
I figured out what the noise was. It is the oil pan hitting the crank slightly. The vacuum forced the pan upward and made it more pronounced. It still does it sometimes... I crawled under and I can feel it hitting on the pan.
Old Mar 19, 2007 | 10:12 PM
Engine: 350 4BBL
Damn, that sounds familiar...
Originally Posted by Supervisor42
... only to find we had dented the pan very slightly and the crank counterweight was hitting it.
Old Mar 19, 2007 | 10:25 PM
Toehead's Avatar
, you called it!
I should have changed the pan while it was still easy!
Cleotiz
Jan 6, 2018 08:56 PM
db057
Aug 22, 2015 08:17 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
gwade12
Aug 8, 2015 08:17 AM
