what 350 will work ??
Old Mar 18, 2007 | 11:11 AM
TON*LOC's Avatar
Car: 1987 firebird trans am
Transmission: 5 speed
Axle/Gears: 4th 10 bolt hope fully it last
i'm looking for a 350 to switch all my 305 tpi parts to (cam, tpi intake system).is there a certain year i have to look for ? does it need to be fuel injected ? or can i just go and pick up any old chevy 350 from the junk yard ? i tried doing a search on here but just couldnt find the answer i was looking for.
Old Mar 18, 2007 | 11:19 AM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
go get any old 350 it will work but i would look for one made after 1986 if you like the roller cam and one piece RMS
Old Mar 18, 2007 | 11:32 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Yep, any old 350 will do. But like stated above, keep your eyes peeled for a 87+ roller block. That will leave the window open for some easier HP later on down the road.
Old Mar 18, 2007 | 11:33 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
87 and up heads have the middle intake holes at a different angle than 55-85
good luck
Old Mar 18, 2007 | 04:59 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
His intake can be drilled to fit either one. Or he could but an aftermarket one and kill 2 birds with one stone. It really doesnt matter which year engine he gets.
Old Mar 18, 2007 | 10:24 PM
TON*LOC's Avatar
i cant just put my cam and bearings in any 350 ? it has to be a roller motor ?
Old Mar 18, 2007 | 10:28 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If the new block was a roller block, you could use your cam in it, but it would be a better idea to upgrade it while you've got the chance.
Old Mar 18, 2007 | 10:46 PM
TON*LOC's Avatar
so i cant put a roller cam into a motor that didnt originally have a roller cam in it ?
Old Mar 18, 2007 | 10:50 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You can if you use retro-fit roller lifters and a cam thrust button.
Old Mar 18, 2007 | 10:53 PM
TON*LOC's Avatar
sounds to confusing guess i'll just look for a 86+
Old Mar 18, 2007 | 10:56 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
87+ is what you want, if you find an 86 or older it will be flat tappet style.
Like ape was saying, you can put roller cams in older blocks, but it costs about 10x as much as replacing a roller setup in a roller block.
Old Mar 18, 2007 | 11:01 PM
TON*LOC's Avatar
sweet thanks guys !!!!!!
Old Mar 19, 2007 | 03:38 AM
Pat Hall's Avatar
Yeah you definitely want to upgrade your cam while you're at it. Your stock 305 cam will be very anemic and underpowered in a 350 motor. Trust what the other guys are telling you too. The 87-up roller cam motors are a vast improvement over the older flat tappet motors!
Old Mar 19, 2007 | 10:35 PM
TON*LOC's Avatar
its the same cam the 350's came with in 87
Old Mar 20, 2007 | 12:05 AM
Pat Hall's Avatar
That just reinforces the point even more. Any cam that runs decent in a 305 is usually not enough cam for a 350. At the very least, you ought to go with the Crane Compu-Cam #2032. The ZZ4 cam would be an even better choice than the Crane.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
milk
Aug 10, 2015 06:26 PM
