Head porting, intake ports finish ?
Old Mar 20, 2007 | 03:05 AM
bvlahov's Avatar
Car: C4 Corvette
Engine: l-98
I've read that it's not best solution to have very smooth finish on
intake ports because fuel don't get mixed well with air if it's too
smooth.
How do you finish intake ports?
Using cartridge rolls (standard abrasives) looks very smooth or is
that rough enough?
Old Mar 20, 2007 | 11:14 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: Head porting, intake ports finish ?
The intake ports should be smooth but not polished. See http://www.sa-motorsports.com/diyport.aspx , Part 2. The 80 grit cartridge roll is the last you use. It's still "rough" compared to the polished finish.
Old Mar 20, 2007 | 11:31 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
if you want to polish anything do the combustion chamber.
Smooth any sharp edges and polish the hell out of it.
Old Mar 20, 2007 | 12:14 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Yup, a "wet 80 grit finish" is what you want, got it confirmed years back by a guy who used to work with F1 cars.
Old Mar 20, 2007 | 01:54 PM
bvlahov's Avatar
Car: C4 Corvette
Engine: l-98
Thanks!
Old Mar 20, 2007 | 06:30 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
not that it was asked, but exhaust ports are like the combustion chambers, polish to a mirror shine.
Good luck with it.
LT1Formula
20
Nov 14, 2015 12:02 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
Jake_92RS
Aug 11, 2015 10:39 AM
mx127
Aug 10, 2015 08:13 AM
