Drive belts and radiator hose needed
Guest
Posts: n/a
Hi,
I want to buy all 3 drive belts and the lower radiator hose
for my 1984 Trans Am V8 5l (air condition). Is there
any company which offers them?
The GM dealer here can does not have them anymore.
Thank you,
Laszlo
Thank you,
Laszlo
Re: Drive belts and radiator hose needed
Any of the companies that sell belts and hoses at auto parts stores should have them. The belts are the same as any other V-belts, European or otherwise; you just need the right lengths.
Try visiting www.partsamerica.com and find out what length belts you need; and convert the lengths to mm, and check your local stores. For instance, the alternator belt is a 7445, which is 7/16" wide and 44.5" long (the part number tells you those 2 measurements.... 7 445). That means it's about 11mm wide and about 1130 mm long. The others can be converted to metric by the same method.
1992 Trans Am
May 10, 2023 07:19 PM
db057
Aug 11, 2015 10:11 PM
