Possible electrical problem(help!)
Car: 1991 Formula
Engine: 5.7
Hi i'm having some trouble keeping the juice in my battery. heres my setup: 1991 Formula 350 converted to carb. stock wire harness is still in there, but i snipped the injector plugs off and covered the wires with electrical tape. not using the ecu either. i have a holley out of tank electrical fuel pump that i'm running on a switch. not the issue is that i'll start it up drive it, but after i turn it off the battery goes dead. any ideas or places to start checking for bad grounds or anything? any insight is appreciatted. thanks in advance.
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
db057
Aug 11, 2015 10:11 PM
