vaccum problem???=blow by???
Old Mar 23, 2007 | 05:12 PM
FOX-GTA_89's Avatar
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
is it possible that a VERY LOW vacum can make a blowby problem... i have smoke comming off valves breether on a brand new engine. Still have this problem while hitting the gas. I dont want to tear my engine apart if it could be a little problem.
i have a prety wild cam
110lsa
232 232 dur .050
480 480 lift
355cu/in
Old Mar 23, 2007 | 05:16 PM
7.0 camaro's Avatar
Car: camaro
Engine: 383
Transmission: 350 turbo
Re: vaccum problem???=blow by???
mine was doing that. it's normal i guess. i just hooked a pcv valve to mine. it should get worse when you get on the gas. thats not too wild of a cam. and has nothing to do with blow by.
Old Mar 23, 2007 | 05:31 PM
FOX-GTA_89's Avatar
i tried the Mr gasket breether with the hose connected to stock pcv loction ...but my TB is eating oil!!!
how did you fix the problem?
Old Mar 23, 2007 | 07:00 PM
7.0 camaro's Avatar
Car: camaro
Engine: 383
take some pics and let us see how you got it hooked up. then i can kinda tell you what you got and need to do.
Old Mar 24, 2007 | 02:51 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Your TB? Is this TPI still? How'd you tune your ECM for that cam? Think it might be running rich?
Lack of vacuum can cause your PCV to not work up to snuff, but that shouldn't make the engine smoke more. What did you gap your rings to?
Most importantly, how'd you seat the rings? HARD?
Old Mar 24, 2007 | 02:54 PM
FOX-GTA_89's Avatar
think i fixed a part the problem...i have no much smoke off valves covers... i did'nt plug the vacum hoses the right way...i blocked the vacum hole under the TB (lt1 intake) and it was the pcv vacuum hose...but still oil comming off dipstick ans oil distributor...
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
