Aluminium Heads???
Old Mar 24, 2007 | 07:46 AM
morty_75's Avatar
Car: 1989 formula 350
Engine: 5.7 tpi
Aluminium Heads???
Hi,
Could someone please clear this one up for me once and for all. Did the third gen' formula 350 come with the aluminium heads or are they iron? I've read conflicting stories in different books. So, what's the definitive answer anybody?
Thank's.
Old Mar 24, 2007 | 09:14 AM
Guest
Guest
Posts: n/a
Re: Aluminium Heads???
Someone actually printed in a book they came with aluminum heads? I'd toss those in the nearest trashcan.
No, Formulas and thirdgens in general did not come with aluminum heads. The only ones that may have (and not all of them) would be Firehawks.
Old Mar 24, 2007 | 01:37 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
The corvette with the "L98" (same engine code as our 350 TPI), had AL heads IIRC. That may be the source of the confusion.
But yea, i'd be leery about what else you read in that book. Is it that fabled book about souping up a third gen? I forget what it's called, but apparently it's filled with misinformation and very little useful specific info. "How to hotrod a thirdgen" is a pretty broad field so...
Old Mar 25, 2007 | 12:16 PM
morty_75's Avatar
Engine: 5.7 tpi
Thank's guys. Can't remember which publication in particular. Probably the old, 'same motor as the Corvette' statement indeed. I've definitely read that the GTA came with aluminium heads.
Anyway, cheers for clearing that one up.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
