(High and Low) Idling Problems - 350 TPI
Old Mar 26, 2007 | 07:43 PM
ihnsane's Avatar
Car: 1989 Chevrolet Camaro IROC-Z
Transmission: A4
About a month ago my car ran fine, then the MAF sensor went, so I got a new Microtech one. The next few days the idle had some slight problems but I thought it would clear up, and it did for a while, but now its getting worse again.
When I start my car in the morning it turns over right away and will fire up to ~1000rpm then down to about 500ish, stutter and stall.
If I hold the rpms @ ~1000+ for a few seconds, or rev it a few times then let off the gas, the rpms will go anywhere from ~800 to ~600, and slowly decrease until it stutters and stalls again.
Once I start driving for a few minutes and the engine warms up the idle will be normal until it starts to idle high. After driving for about 5 minutes or so the idle will be high (~900rpm in drive not moving, ~1400rpm in neutral or park).
This is very annoying because when I start my car n the morning I cannot get out and let it warm up, I have to sit there on the gas to keep it from stalling. Also, after I drive for a while and I get to a neighborhood or 15mph zone or whatever my engine is idling high and I have to stay on the brake because the trans. is engaged.
So anyway, does anyone have any idea whats going on with this thing?
Thanks in advance for any advice.
btw its a 350 TPI I got about 6 months ago from a friend of my dads. It was rebuilt and had about 15k miles when I got it. Stock except for cams (not sure what kind)
Old Mar 27, 2007 | 11:34 AM
ihnsane's Avatar
Transmission: A4
Re: (High and Low) Idling Problems - 350 TPI
anyone...?
Old Mar 27, 2007 | 11:59 AM
ryanz53's Avatar
Car: 84 Camaro
Engine: 81 oldsmobile 307 5.0L
Transmission: 700r
Axle/Gears: 3.75
hi.
unplug the maf sensor and see if there is a difference.
mass air flow sensors usualy go uncleaned and unnoticed until they fail.
your original sensor might not have failed, but just been too dirty to function.
I would suggest taking everything apart and giving it a good cleaning (contacts and all).
Old Mar 27, 2007 | 08:57 PM
ihnsane's Avatar
Transmission: A4
Thanks.
Ill try unplugging it and try to clean it a little tomorrow morning if I get up early enough.
If not after school Ill tear it all apart and clean everything.
Hope this solves it. I've got a bunch of other problems in the car to tackle.
theshackle
Sep 17, 2020 08:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
