Cutting out at 2500 rpm ???
Old Mar 27, 2007 | 11:36 PM
lasher_350's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 9 bolt 327
Okay, some dimwit that I got my camaro from put in an old points style distributor and coil on the 350....and it idles like a champ! purrs like a kitten, but I can't get above 2500 rpm without it coughing and sputtering...back under 2500 and it's smooth sailing....the kid thought it was the holley carb he had on it, but I have a good carb on it that I had on my bashed up T/A...so I know it's not the carb. Any ideas? Could the coil be a very low voltage and just stop working at 2500 rpm? Engine is from a 93 C1500....no smog, no electronics hooked up to the engine whatsoever...just old school motoring
Old Mar 28, 2007 | 12:03 AM
77monte's Avatar
Car: 77 Monte Carlo, 89 Firebird Formula
Engine: 355's
Transmission: TH350's
Axle/Gears: 10 bolt 8.5 3.73, 9 bolt 3.27
Re: Cutting out at 2500 rpm ???
Pull the points distributor out of there asap.. it has no room in any car.. go buy a stock hei replacement or a performance piece if you want.. chances are the thing isn't installed correctly or set up right at all...
Old Mar 28, 2007 | 12:57 AM
lasher_350's Avatar
Engine: 5.7 L98
I have a brand new distributor/cap/rotor/coil (65,000volt) that just arrived today...will have it in tomorrow if it isn't storming too badly
Old Mar 28, 2007 | 03:01 AM
1983Fbody's Avatar
Car: transam, el camino
Engine: 415
You'll probably have to change your wires 2 when switching from the points style dist. to the HEI.
I had points on an older chevy inline engine and I thought I had it running like a top w/ new wires, plugs, cap, points, etc. I was constantly tweaking and tuning trying to get more from it- Then I read somewhere that the newer inline engines from the 80's used a HEI dist. and it would drop right in place so the next time I was at the Jyard I picked one up for 15bux. I didn't do anything to the HEI except scrape the contacts inside the cap, dropped it in w/o setting the timing and just amazing what a difference it made BEFORE adjusting it. On another engine I switched from TBI to carb and needed a dist. so I sought out the nastiest looking HEI from the local J-yard, I didn't even pull the cap on that one to look at it, dropped it in and vroom- got 20,ooo miles and still going on that one..
Old Mar 30, 2007 | 04:42 PM
lasher_350's Avatar
Engine: 5.7 L98
Okay, got the new HEI in, new plug wires...and yeah, what a difference it made! It revs until I let off of it...sweet!! Anybody have any use for an old points style distributor, cap, rotor and wires?? hahah
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
Regal105
Aug 23, 2015 03:45 PM
TreDeClaw
Aug 14, 2015 06:58 PM
